CMI E-Tops, Standard Bravo tailpipes with aftermarket heads >
Old 10-26-2024 | 07:34 PM
Default CMI E-Tops, Standard Bravo tailpipes with aftermarket heads
Anyone have any experience with CMI E-Tops on a BBC using AFR heads with 3/8" raised exhaust ports, will standard Bravo location tailpipes with the flex-flare connections line up close enough with the transom tips or will I need special custom made tails
THE NEED FOR SPEED is offline
Old 10-26-2024 | 08:03 PM
TomZ's Avatar
Can’t say for a Bravo but on my TRS setup they fit but were pushing it. Silicone “hump” hoses should give you some leeway.
TomZ is offline
Old 10-28-2024 | 03:51 PM
BBYSTWY's Avatar
In my case...no it did not work. My tails aren't "standard" bravo however...I ended up removing the tips, filling the holes in the transom, and recutting them 3/4" higher. I have had the boot between the tail and tip fail due to misalignment when I bought the boat and that's not something I want to experience again. Just an FYI...not only do they go up with the raised exhaust ports but they also go out a little due to the angle at the header flange to the head...just something to keep in mind. More work but if it were mine...I'd move the tips.
BBYSTWY is offline
