8.3 whipple vs 1271/1471 blower >
Old 12-03-2024 | 10:02 PM
Default 8.3 whipple vs 1271/1471 blower
What are some thoughts on the two types. Cant decide which route to go
joey O is offline
Old 12-03-2024 | 10:19 PM
icdedppl did a great write up going from roots to 8.3 id look into that thread
Cms51 is offline
Old 12-04-2024 | 09:37 AM
F-2 Speedy's Avatar
EFI Whipple for the win..........the newer 3.8 will make big power also
F-2 Speedy is online now
Old 12-04-2024 | 10:50 AM
Whipple for sure.
The idle bypass valve helps quite a bit at idle.
I`d only use it 598 and up in ci.
ICDEDPPL is offline
Old 12-05-2024 | 10:41 AM
Not a 8.3 but a 4.5 Whipple on a 7 Liter LS. Don't think a 8.3 is warranted the new Revs of Whipple's are more efficient.
Definitely Whipple. Newer Tech and features Not a 8.3 but a 4.5 on a 7 liter LS 1325hp/1160tq. a stout piece for a new project.
LakeBoat4 is offline
Old 12-05-2024 | 07:06 PM
I used to have Borowskis build my engines and dynoe there back in the day till Ken went all gay for LS everything .
ICDEDPPL is offline
Old 12-05-2024 | 08:02 PM
F-2 Speedy's Avatar
Dont know how well that two stage pump mounted that high will perform
Old 12-05-2024 | 10:55 PM
You are exactly right. That is where Ken had it mounted and he is not a boat person, it is going lower. Totally wrong for a boat.
As for Gay Ken he is following the money. LS is better these days to a BBC. I have to agree so that is why there is a LS in my future. LS 1325hp 427cu/in. to old BBC 570cu/in quadrotor 1400hp. plus the weight. got them both just in different platforms.
Have to say the 4.5 Whipple is taped out on the 427 @1325hp running 18000rpm@21psi with meth. It can not run a 570cu/in plus at that level. Even a 5.0 or 8.3 is the same supercharger just run from the opposite rotor. 16000 to 12000 rpm I think is maxed out as well on bigger cu/in motors.
Old 12-06-2024 | 09:23 AM
If you do that Id be curious to know how long that LS last at those boost numbers and HP.
That`s going to be significantly more cylinder pressure since the displacements isn`t there .
ICDEDPPL is offline
Old 12-06-2024 | 09:57 AM
It is a trade-off for displacement vs boost as you know.
The Teague 570 quadrotors are 1400hp @ 14psi. This 427 LS is 1325 @ 22psi with spray.
This boat will only be on inland lakes and rivers so no way to hold it wide open for long. It will live its life in the 40-90mph range. Initially it is propped for 135mph @ 6800rpm's with slip..Weight is not an issue.
This is the 28 foot hull ready for rigging in Havasu.
