How much boost on 91 octane >
Old 01-11-2025 | 04:44 PM
Default How much boost on 91 octane
My engines are rebuilt 525efi with rods, pistons, stock compression, Cometic gaskets with studs, Teague stage 3 camshafts with whipples and MOAC intercoolers. I am running at 6000ft elevation and have pullied to 7psi but I am looking to add some more boost and am only seeing 5400rpm. Whipple has told me to just pulley it down to get 11-12psi, just looking for some opinions.
sgett775 is offline
Old 01-12-2025 | 10:23 PM
I'd say you are already maxed out for 91 octane at 7psi.
Griff is offline
Old 01-13-2025 | 09:11 AM
I'm pushing about 800HP with a 3.3 whipple and cometic gaskets, aluminum heads, stock compression. I run 92 octane and 9psi at 5,500rpm. I have looked inside and don't see any evidence of detonation so far. I'm at sea level. I'm not going to push it any further though. Hope that helps.
87MirageIntruder is offline
Old 01-13-2025 | 02:33 PM
11-12psi you`ll be collecting parts out of the bilge.
I wouldn`t go more than 7 psi.
ICDEDPPL is online now
Old 01-13-2025 | 02:40 PM
F-2 Speedy's Avatar
Whipple wont be sending you any money when your engine blows @ 11 lbs of boost
F-2 Speedy is offline
Old 02-06-2025 | 02:28 PM
Ill be upping the octane to 95 and turning my fuel psi up a bit.
sgett775 is offline
Old 02-06-2025 | 03:58 PM
F-2 Speedy's Avatar
What ECM are you running
Old 02-06-2025 | 04:00 PM
MEFI 4. I would like to go Holley eventually since the 555 pcms were deleted.
sgett775 is offline
Old 02-06-2025 | 04:03 PM
F-2 Speedy's Avatar
Where is the limiter set ? stock 555 controller on a 525 is 5350
Old 02-06-2025 | 04:07 PM
6000rpm, my Whipple setup is older, the 555 was deleted and an MSD ignition and MEFI4 was installed.
sgett775 is offline
