1996 7.4 Piston Rings???? >
Old 12-07-2002 | 06:11 PM
cheitman
Question 1996 7.4 Piston Rings????
I am rebuilding a 1996 7.4 non-mag 454. I am still standard bore and have tried Sealed Power SLP-9905 rings. The oil rings will not work. They will not compress far enough to make it into the bore. Ther must be a special ring required for this piston. GM wants $46.00 per hole for factory rings and they can't tell me if they're the right ones. Has anyone else experienced this and have the Sealed Power part number. I am using stock pistons.
Old 12-07-2002 | 07:46 PM
Six Leg Dog
I have seen a ring grinder,to set the end gap.How much do they overlap if you put just the ring in the bore?
Old 12-07-2002 | 08:02 PM
blown formula's Avatar
I guess the first thing to do is find out if your stock pistons require Mercruisers METRIC rings???? Some stock 454's do have metric rings. Nothing else will work.... if not, use a ring grinder as mentioned.
blown formula is offline
Old 12-07-2002 | 08:20 PM
cheitman
has nothing to do with grinding the rings. They fit the bores fine, the piston needs a certain type of ring. I just need a part number other than OEM.
Old 12-08-2002 | 01:31 PM
DJRITTER
Try Federal Mogul E233K piston rings.
Old 12-08-2002 | 06:03 PM
cheitman
Are the E233K a plasma moly or std. moly? I think that number is a Std. replacement ring 5/64, 5/64 & 3/16 oil ring but I'll check, thanks>
Old 12-09-2002 | 11:29 AM
Cignificant's Avatar
I have a partial set that I used when I rebuilt a 454 Magnum years ago. I screwed up one of the oil rings so had to buy a second set. Here's the specs from the box. I'm trying to sell these if you're interested.
(1) Set of Speed-pro piston rings - missing one set of oil rings
4.25 x .078 (8) Top rings
4.25 x .078 (8) Middle rings
4.25 x .1875 (7) Oil rings
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 12-09-2002 | 06:58 PM
cheitman
I just need the oil rings but thanks anyway.
Old 12-09-2002 | 08:07 PM
Crazyhorse's Avatar
E233K is a standard moly, SAE, as you mentioned.
Crazyhorse is offline
Old 12-09-2002 | 08:14 PM
cheitman
I think my machine shop may have found the number. E533K or E553K, however, these are not plasma moly so I will be buying the entire set for only the oil rings. Anyone need the compresssion rings?
CN24
10
02-23-2008 12:14 PM
dinopaul2
2
06-27-2007 04:59 AM
Smitty
2
04-03-2005 11:05 PM
Back4More
11
12-24-2004 12:43 PM
humpster
2
09-15-2004 12:04 AM
