Flywheel difference Top and Bottom Mount Starter >
Old 02-22-2025 | 07:17 AM
Default Flywheel difference Top and Bottom Mount Starter
Can someone school me on the difference in top and bottom mount starter flywheels/ring gears. I am going from the bottom mounted starter on the Merctrans to a top mounted starter on the borg warner velvet drive transmission. I read sorting though posts that the ring gear could need to be flipped? I didn't know if that means from the the back of the flywheel to the front of the flywheel, or just turning it over.
Thanks, the machine shop has it now.
SkiDoc is offline
Old 02-22-2025 | 08:29 AM
ring gear needs to be moved from the inside of the flywheel to the outside(clutch surface.you'll see separation of the mounting surfaces when you pop the ring gear off.so,move ring gear to the clutch/adapter side of flywheel
sutphen 30 is offline
Old 02-22-2025 | 12:51 PM
Thanks,,,, That’s what I told my machinist and he thought I had lost it.
SkiDoc is offline
Old 03-23-2025 | 11:31 PM
Originally Posted by quitshore1507
Let me know if you need more clarification!
I need more clarification................that is not obtained from AI or ChatGPT
Lets hear a human response???? So how is life in Washington State???
Griff is offline
Old 03-26-2025 | 08:10 AM
I read some information on ring gear teeth before I sent the flywheel to the machine shop. Some of the automotive teeth on the ring gear are not symmetrical. It appears mine is symmetrical. If there is a difference I can not see it. These photos are after the machine shop moved the ring gear. I did not specify the orientation of it.I don’t have the engine off my stand yet to mock up the bell housing and starter. Going to be good or no? Thanks
SkiDoc is offline
Old 03-26-2025 | 11:17 AM
I have a top starter flywheel I can post some photos and measurments. For a BBC, but the alignment, ring gear, bellhousing etc should be the same for SBC.
Tartilla is offline
