Alpha repair time >
Alpha repair time
Alpha repair time
Old 03-11-2025 | 05:44 AM
Default Alpha repair time
Question for you guys that do this for a living. What is a fair time to charge to change gimbal bearing,all the boots and bellows, and impeller? I know it will take me longer than it should but want to be fair to the guy.Alpha 1 gen 2 Thanks
liberator221 is offline
Old 03-11-2025 | 06:26 AM
Completely depends on how easy it comes apart. Charge by the hour, but charge a good percentage less than whatever your local marina does to be fair. Around $1k would be a decent estimate
Ryanw10 is offline
Old 03-11-2025 | 08:09 AM
Looks like parts are about $500 (quicksilver) I guessed about 7-8 hrs shop time. Thanks for your input.
Old 03-11-2025 | 06:42 PM
seafordguy's Avatar
If it comes apart I can’t see it being more than a few hours. I’ve done my Bravos a NUMBER of times.
I'm not a guy that beats up or questions shop times, but I would definitely think it’s a few hours max.
Make sure you use OEM - got screwed on that before and had to pull mine back off when shift cable boots tore.
seafordguy is offline
