Deep Cycle Batteries - What Brand?
I need to replace my Group 27’s again this year. The current set barely lasted a season. The previous set lasted six seasons. My experience in general is that auto/marine batteries aren’t what they once were. What brands have you guys had good luck with lately?
If you're looking for cheap, Walmart. And I don't mean to disparage that choice. It's a decent battery at a good price. I have one in my truck (496 Chevy).
Spend a little more and get a better warranty, Batteries+Bulbs "X2Power"
I’ll check out the ones you mentioned. Lowe’s also has Deka deep cycles for a decent price. East Penn (Deka) has historically made good batteries, I’ve been considering them.
Figured I’d see what others have had good luck with lately.
I always buy Walmart marine batteries. (25 years now) They are made by JCI. Bought 2 new ones 3 years ago.
https://www.walmart.com/ip/EverStart...5-CCA/20531539
I bought my Hitachi excavator in 2011. They 12v batts were not new. They're in series for 24v. The 4 cyl engine is not that big, about a 60hp diesel. I've ressurected them from dead a few times over the cold seasons. I'll likely replace them next season as maintenance. Insane life on them.
I have Mack batts in the Mack dump tandem axle dump truck. 12v. I have 2 in parrallel. I've had just one in, and was strong enough to start the 673ci inline 6 diesel.
I've had these since Dec 2017, and they gave out their last gasp last year. I didn't use them much from 2020 to 2024 though. I had a current draw in my system that dropped them down hard...they recoverred well.
My plan is to get new ones for the boat...and then switch them to the machinery after 2 years. Buy new for the boat.
950 cca
13" long
8-5/8" tall
6-3/4" wide
950 cca
13" long
8-5/8" tall
6-3/4" wide
It may also be that I’m just not getting out on the water as much these days. Sometimes a month or more goes by without use. Unfortunately, I can’t keep a tender on them when not in use.
I am Griff. I’ve used DC batteries in every boat I’ve owned in the past 30 years. Never had an issue. I know some people run one DC for house power and one starting/charging for the engine(s).
My 350 Mag MPI would crank ok with a deep cycle - but it wouldn't fire because the PCM wasn't seeing enough voltage to fire the injectors. I changed to a starting battery and all is well.
As for the tender issue - have you considered a solar charger? They can deliver enough amps to maintain a battery, certainly better than nothing.
Cranking Battery vs. Deep Cycle Marine Battery
