Mystery BBC please help >
Old 05-12-2025 | 07:31 AM
Default Mystery BBC please help
Recently Purchased a 1992 IMP Europa 240 that had a BBC and Bravo 1 swapped into it sometime around 2006. I am trying to get an idea of what kind of horsepower numbers I should expect from the engine. This is what I know about the engine:
Block Casting number #10114182, 1991 and up gen V 454 CI 4 bolt main standard deck block. Mercruiser 454 Magnum Long block, Forged pistons, rods, and crankshaft. Early 90's 454 mag pistons. Gm std. # 14097021. 13.8cc dome 8.8:1 Compression ratio.Cylinder Head Casting #14097088, cast iron 118cc open chamber rectangular port heads. Largest as cast GM production iron head ports (325CC intake runners). Retrofit hydraulic roller camshaft (unknown cam specs) with Crane Gold roller rockers. Weiand Single plane aluminum intake manifold (port matched to heads). Holley #9022 4150 style 800CFM double pumper w/ mechanical secondaries.
What kind of HP numbers should I be expecting out of this set up?
Capt.Jack is offline
Old 05-12-2025 | 07:45 AM
SB
401.6 ?
SB is offline
Old 05-12-2025 | 08:20 AM
That’s an oddly specific number. Not sure I understand your response.
Old 05-12-2025 | 09:16 AM
I would agree 400 is in the neighborhood.
SecondWind is offline
Old 05-12-2025 | 09:19 AM
I didn’t mention it in my previous post but there is a very noticeable lope at idle, so I am fairly certain there is a larger cam than the stock 454 mag cam. Not sure how much of a difference it will make. I would assume the limiting factor on my setup is the 8.8:1 compression ratio?
Old 05-12-2025 | 12:41 PM
The limiter in your setup is the 088 heads.
The 365 mag hp rating I believe is at the prop. The GM marine forged BBC offerings were pretty much identical. They were rared at 390hp @5200 at the flywheel. Important to compare the apples to apples.
This would have been with cast exh manifolds. Manifold upgrade would likely net some better peak tq and HP #s.
As mentioned, the 088 heads have maybe the worst exh port GM made. Flows 165cfm at 0.400" lift. That is SBC territory. Intake ports are not bad for flow at 240cfm ish at 0.400" intake lift. That is great for a SBC with a 195cc port. Prett lazy on a 320cc port.
These heads were on the 800SC 420 blown engines, so they can make power, but that exh port is requiring a lot of gross energy to pump out.
My 088 heads have been machine in from the factory so there is very little to no venturi taper underneath the seat. The only real way to fox that is to put larger valves in and rework the seat, so the valve port diameter is 90% of the valve size.
These engines cam with a single pattern cam 224/224 @ 0.510" lift. Hyd FT. 115.5° LSA.
The L29 BBC Vortec heads flow better for a 450hp marine application.
Without knowing what cam you have in the engine, difficult to determine where you are HP wise.
Single plane intakes here are not as efficient as a good dual plane. You don't get as good of a signal to your carb, and you're likey not turning enough rpm to benefit from them.
A good dual plane rec port style intake and a good flowing exh. system, would wake it up.
If you prop for higher rpm 5500 to 6000, with proper cam and springs, the heads will flow, and you'll make more HP.
088 heads are great for what they are, but not worth putting any paid port work into them etc.
Tartilla is offline
Old 05-12-2025 | 02:37 PM
boat weights about 4200lbs with gear and fuel, I’ve got a 24p bravo 1 prop. Hoping for mid 60s. Is this too optimistic?
Old 05-12-2025 | 05:07 PM
Hard to say. If the cam has been done, it's going to want to breathe above 5000, vs the 4600-5000rpm suggested by Merc. Something like that.
You don't know if the cam's been done, or what valve springs you have in there.
What exhaust have you got?
Post some photos.
4200 lbs isn't super heavy, but getting to 60mph is your first goal.
What drive do you have?
Assuming you have a 1.5 drive reduction.
24p prop
5000rpm
12%slip ish
Gives you 67mph.
Depending how it runs with the 24p, dropping down a bit may be beneficial, if you can't hit at least 5000rpm.
Tartilla is offline
Old 05-12-2025 | 05:56 PM
Post some photos.
24p prop
5000rpm
12%slip ish
Gives you 67mph.
can has def been done. Boat has a very noticeable Chop at idle. Retrofit comp roller lifters are in it as well as crane roller rockers and aftermarket valve springs. Seems like someone built it to turn some RPM. I’m hoping boat is lite enough to tolerate the 24p prop.
Old 05-12-2025 | 06:51 PM
Here is a short video of the idle
https://youtube.com/shorts/cVviyM_rl3g?si=cVD-HiOijsyPdTgu
