Oil lines for gen 4 454 Mag-Is is ok to replace with braided lines? >
Old 06-26-2025 | 11:49 AM
Default Oil lines for gen 4 454 Mag-Is is ok to replace with braided lines?
I have a pair of very mildly hopped up 88 454 Mags that the oil lines have begun leaking at the fittings. From what I am seeing online is each line is around 200 a piece and if I need to do the coolers its round 300 for that pair. Pretty much OEM is 700 bucks per motor/1400 for the pair. Is there anything stopping me from running some -10 braided lines on these. I have not dug too far in yet, but I am assuming the filter adapter and block adapter are NPT threads? I can probably replace all of the lines on 1 engine for around the price of a single OEM hose. Am I missing anything that is stopping me from going this route? Any help is appreciated!
regalman4925 is offline
Old 06-26-2025 | 11:51 AM
I just looked at the chart again, not that it matters much, but I think there is actually only 3 lines on this setup since there is no oil thermostat, the cost is still quite a bit.
Old 06-26-2025 | 07:44 PM
Rookie's Avatar
That's all I ever use 10AN.
I don't recommend stainless braided. Might have to change a couple fittings from steel pipe to AN fittings.
Rookie is offline
Old 06-26-2025 | 07:59 PM
That's exactly what I have in mind. I was going to use the black braided lines, whatever material that is. It appears that I can do both engines for around 250 dollars. It is hard to justify oem for at least 4 times the cost!
Old 06-27-2025 | 01:40 PM
I've always used evil energy -10AN lines, braided PTFE
CheckmateScarab is offline
Old 06-27-2025 | 02:32 PM
F-2 Speedy's Avatar
F-2 Speedy is offline
Old 06-28-2025 | 02:54 PM
That's exactly what I was planning to use, I have everything in my amazon cart besides the fittings to thread into the engines parts. I didn't want to say the brand, I figured i would catch **** for buying off brand, lol. I have had good luck with their products so far.
