Prop depth >
Prop depth
Prop depth
Old 06-27-2025 | 09:34 PM
Default Prop depth
Have a 2007 26 outlaw, rebuilt 496 HO specifically for Whipple. No extension box. Maybe later. Running Teague Platinum outdrive with IMCO standard length lower after blowing Bravos. My question is, what would you suggest for prop shaft CL to bottom of pad distance?
26 Outlaw Bad Influence is offline
Old 06-30-2025 | 06:59 PM
I may be complicating things, but I’m starting to consider some other options. A question I have is with regards to adding an extension box. My assumption is that a neutral box doesn’t change your ex dimension and so the only change that is possible would be to add a Shorty ifit looks like that will run better. However, if you add an extension box. it looks like that will run better. However, if you add an extension box that raises the X dimension you could use the standard lower but net a higher prop. The question I have is this is it better to run a neutral box and a Shorty or run a box that raises the next dimension and run a standard?
Old 06-30-2025 | 09:43 PM
3 threads on the same topic will complicate things. The other 2 threads have been merged together.
Griff is offline
Old 07-05-2025 | 07:02 PM
No worries, I’ve just seen where people don’t look at all the forms and I wasn’t aware that forms were linked together
