Need upgraded drive advise
2003 velocity 280 with a new xr outdrive, about 30hrs on unit.
Current engine is a sci 575 with some upgrades making around 650-675hp.
Engine is getting a new cam, heads and intercooler, power will be around 775-800. I also plan on installing a 565 big block with around 850 hp once this 575 gets close to service interval.
The xr is working perfect right now, I never smash the throttle down fast or haul butt through 4 ft waves hammering on the drive. Just roll into throttle slow, Just the way i like to drive.
What is the logical move for a stronger drive set up without spending 25k? Max machine gears? maybe just do a scx upper? i am Not very educated on the drives yet. Thanks.
So the upper on the xr is the weaker link with the drive? Save money and get the scx upper and that should be a decently strong set up? And yes we are going to be very conservative on the timing ramp up to try and kill some torque.
I bought one from CP Performance and had a good experience.
https://www.cpperformance.com/p-1107...ete-black.aspx
