carter AFB/weber 9780S rebuild help >
Old 08-28-2025 | 07:31 PM
Default carter AFB/weber 9780S rebuild help
I've torn down, cleaned and almost have a Weber 9780S carb back together...but have 2 parts from the kit that i cant figure out...
one is a rubber seal maybe 1/4" in diameter, thought maybe accelerator pump shaft? but it s too tight on the shaft...the other is a thin ,metal washer, maybe under accellerator pump spring?
any help would be much appreciated..
Zekester is offline
Old 08-29-2025 | 02:05 AM
the small one goes under the choke housing..
Zekester is offline
