Standard Bravo gears-are certain years stronger than others? >
Old 09-04-2025 | 03:17 PM
Default Standard Bravo gears-are certain years stronger than others?
I keep seeing at least one guy on facebook claiming that the 99 and older bravo gears are stronger than the 2000 and newer. When I started learning to rebuild drives, everything I have read said that the newer thick floor upper gears were stronger and the fix to the older upper issues. I have read nothing that has said that the lower gears are different years. Is this internet BS or is there factual information here? I have googled this and have not found anything saying this, what I have found actually backs up the newer thick uppers being stronger. I just built a pair of uppers with thick floor gears that I have been thinking were stronger than my older pair of drives, maybe I am incorrect? I am here to learn either way
regalman4925 is offline
Old 09-07-2025 | 07:07 AM
The problem with the pre 2000 gears is that they would blow the floors out of the gears, if you’re good on the sticks, you may not have a problem with this
I haven’t heard any real issues with the newer( X style) gears
JaayTeee is offline
Old 09-07-2025 | 02:00 PM
I've heard the same thing abt older drives having better gears.
zz28zz is offline
