Water in K-Plane Trim Tab Pump >
Old 09-08-2025 | 11:53 AM
bn
Default Water in K-Plane Trim Tab Pump
I have water getting into my K-plane trim tab pump some how. I have checked fittings on the lines and they are tight. Any ideas as to what would cause water to get into the pump?
bn is offline
Old 09-08-2025 | 12:02 PM
F-2 Speedy's Avatar
might be a ram seal leak ?
F-2 Speedy is offline
Old 09-08-2025 | 03:18 PM
Only place for water to get in is a hose or a ram seal
Griff is offline
Old 09-08-2025 | 07:33 PM
Rookie's Avatar
Can't really tell if there is water in the reservoir from pic. Looks foamed from maybe low oil level.
If actual water in there disregard.
Rookie is offline
Old 09-09-2025 | 12:37 PM
bn
It's definitely milky and filled right up to the bottom of the filler neck. Anyone know if they sell a seal replacement kit for the ram? These are the only parts that I could find K Plane Trim Tabs & Accessories
bn is offline
Old 09-09-2025 | 12:54 PM
Try here.
https://www.perfprotech.com/mercury-...tnbr=845760T09
Or, maybe try a local hydraulic shop.
Shah Mat is offline
