Gozzy 34 SuperVee
Old 10-08-2025 | 02:05 AM
Default Gozzy 34 SuperVee
Hi all
A new member from Norway here.
I bought an old racing boat that was raced in a series called SuperVee here in Norway.
The boat was buildt here in Norway.
Not sure what the setup was back then, looks like a trimax drive or something similar.
But its been a pleasure boat the last 10 years now, and its been running with a supercharged Teague V8 and a Speedmaster 6 drive.
I bought the boat without the engine, but with the drive. The drive needs to be rebuild after it broke down. Not sure how bad it is yet.
But could somebody tell my what generation drive i have?
Tried to do some research, and from what i understand it was first the K-Drive ( Kieckhafer) , then Speedmaster 6, then 6A and then the M6?
Do i have the Speedmaster 6? And is it worth rebuilding? Can i still get parts for it? When did the drive get reverse internaly ?
Helleberg is offline
Old 10-08-2025 | 08:14 AM
Veteran: Navy
Can't help
but what a great looking boat
Good luck,
powerboatr is offline
Old 10-09-2025 | 01:04 AM
Originally Posted by powerboatr
Can't help
Good luck,
Tnx! Hope this winter will be short..
Old 10-09-2025 | 01:06 AM
But can anybody recognize my drive ?
Old 10-09-2025 | 05:28 AM
It’s a 6
The skeg has been modified, but by the looks of it, I’m guessing it’s a wet
sum
They don’t have any shifting provisions in them,
JaayTeee is offline
Old 10-11-2025 | 10:50 AM
Originally Posted by JaayTeee
It’s a 6
sum
Its wet. But do you think its a first gen?
Old 10-11-2025 | 10:53 AM
Found the problem. A gear in the upper housing is missing half of the teeth. Where to order parts? And where to find a manual?
Old 10-11-2025 | 10:54 AM
Old 10-11-2025 | 12:19 PM
mercruiserparts.com
there’s a section. All else, the manuals are in there
JaayTeee is offline
Old 10-11-2025 | 01:00 PM
mercruiserparts.com
Thanks, think i found it. But it doesnt ad up, my messed up pinion gear has 17 teeth, and the lowest option is 19? Either way, all options are "out of stock" wich im guesing means " to old and out of production " ... Any alternativs?
