1992 HP465 Springs valves recommendation
Hello guys,
I have a 502 465HP Carb 1992 flat tappet with 170h and gill thru hull. I purchased it last year and had a very funny summer, no mechanical issues.
This winter I want to take care of the engine, as I don’t know about history maintenance.
I think is wise to begin changing the valvesprings.
I read in a tread about HP500’s the following parts:
- Valve Springs Comp 929-16
- Retainers Comp 741-16
- Keepers/Locks Comp 612-16
- Seals Comp 505-16
Is this set appropriate for a 465HP?
Comp Springs 929 are DISCONTINUED. What would be the replacement?
Other option it would be to follow up with Crane. I read 465 it’s a little bit less aggressive with the springs that the HP500. Third option could be Isky.
It would be a BIG HELP, if you can recommend me the right parts # you would use to update the valve train please. (Valve springs + retainers + locks + seals)
Thank you,
Doc.
- Seals Comp 505-16
Thank you,
Doc.
Thank you very much Bill. The engine is 170h. But 33 years old. It’s what make me worry.
there is an other spring # that would be better option than 929?
If not, I will inspect all springs and set a preload again to minimise any play or noise. If any spring it’s damaged I will substitute with an OEM.
