Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Miriah engine mount block >
Old 10-28-2025 | 06:03 PM
Default Miriah engine mount block
Hey guys, I need some help with coming up with something for this damaged engine mount block....The block was rotted out as well as the stinger...I have replaced like 4ft of the stinger and I'm butting them in...That part is coming along fine....What is the best way to make this block...I bought 1" think marine plywood and I was gonna stack them with a layer of mat between them and then cut that angle in on a table saw once they are glued...Does that sound ok? Thank you..
Mariah212 is offline
Old 11-23-2025 | 12:07 AM
I would not use plywood it can swell and shrink, bolt on some 4 inch angle iron to stringer and use angle iron to mount engine mount on. Or use 1 inch solid hardwood instead of plywood
496blower is offline
Old 11-23-2025 | 10:44 AM
that fuel fill hose must be replaced this looks like a huge project! never seen the mount rust off the block?
boostbros is offline
Old 11-23-2025 | 10:59 AM
More pics would be good
