What’s everyone working on? >
What?s everyone working on?
Old 11-07-2025 | 03:16 PM
Default What’s everyone working on?
What projects or upgrades are you guys doing this season? Let’s see what everyone’s been up to!
Triage is offline
Old 11-07-2025 | 05:58 PM
Just finished my dash update,
before
boatnt is offline
Old 11-07-2025 | 05:59 PM
After
Old 11-07-2025 | 07:48 PM
seafordguy's Avatar
Headliner torn out fixing leaking deck vent - a Cigarette craftsmanship issue (too thin of fiberglass).
seafordguy is offline
Old 11-08-2025 | 12:48 PM
Guys,
Let's see... Where to start....
Fought a coolant leak all summer long after the rebuild. Finally found what a drip hanging from the bottom of the circ circ pump, couldn't get to it in the boat, so I decided to pull the engine. Tore into it. Discovered, during the rebuild, the builder reused the connecter between the crossover and the circ pump, which is hard and deformed. I'd already ordered a new circ pump, so I ordered a new connecter to go with it. Fingers crossed.
Decided, while the engine was out, to address the cam I should have swapped during the rebuild. The HO cam just seems to be hitting a wall at 5K, no matter what we do (short of less prop). Tried sourcing a custom cam that would mimic the Raylar 211 under the 1.8 ratio rockers we opted for instead of a cam, found that to be more elusive than I thought it would be, so I ordered it from Raylar and a set of 1.7 Scorpions. The 1.8s will be in the swap shop before long.
Finally getting around to the full hydraulic steering conversion everyone was giving me sh!t over during the rebuild.
Thanks. Brad.
Brad Christy is offline
Old 11-08-2025 | 04:29 PM
Old 11-08-2025 | 06:28 PM
seafordguy's Avatar
That Sutphen has some great lines…..
Old 11-09-2025 | 06:10 AM
offshoredrillin's Avatar
So glad that boat went to a good home. when i looked at it for a friend when it was in MD, for as long as it sat, it was as solid as a new build.
offshoredrillin is offline
Old 11-09-2025 | 09:27 AM
Active Streak: 30 Days
Keep them coming! Me: tearing out mechanical fuel pumps mounted to sea water pumps. Done with leaking oil in the bilge from crappy fuel pumps leaking fuel into the drive oil in the sw pumps. Replacing a drive tilt extension hose from the pump to the transom assembly, sub box under the rear seat, finally succumbed to the humidity and rainstorms. W&W box will fix that issue and a couple of dock rash places on the bow.
Helmwurst is offline
Old 11-09-2025 | 12:24 PM
I'm going to go outside the box since the boat is good to go for next year, but sniffing around for another😁 but I did just finish putting hardwood in all the bedrooms per my wife's request, so no more carpet! But it's making it easy to shop boats now😂
blownhammer2000 is offline
