Nortech 40 Roadster
Old 11-09-2025 | 04:43 AM
Default Nortech 40 Roadster
Nortech 40 needs quad 500r to run similar speeds as similar sized cats with twins. Main differences ?
Chaudron33 is offline
Old 11-09-2025 | 06:54 AM
Weight
SecondWind is offline
Old 11-09-2025 | 03:22 PM
Bigger and heavier boat. Not rocket science
Nate5.0 is offline
Old 11-09-2025 | 05:34 PM
They were claiming it’s the fastest stock OB boat
hogie roll is offline
Old 11-09-2025 | 07:25 PM
How fast does this 40 run with 4 x 500s? And, if known, how much does this model cost?
Smarty is offline
Old 11-10-2025 | 10:22 AM
Also has a narrower tunnel so less lift. Plus it's the old hull bottom. I'm sure there's more technology that goes into these new outboard cats in addition to lighter weight and wider tunnels.
Install a pair of 500rs on ANY old inboard cat model and see what the speeds are.....
offshorexcursion is offline
Old 11-10-2025 | 11:05 AM
They will do 142 out of the box with unmodified 500's. There is a post on FB of the Garmin display.
Diamond Dave is offline
Old 11-10-2025 | 08:41 PM
Another one post wonder.
ICDEDPPL is offline
Old 11-11-2025 | 08:06 AM
The boat is better with 1100's and will consume less fuel
baja27 is offline
