Fuel sender
Anyone have any experience with this Holley fuel sender? It sounds like a good idea for boats. What are your thoughts???
Holley 19-250-1 Holley Easy Level™ Fuel Level Sender https://share.google/E3XINyQfNkQnJHgBc
Padraig
Padraig
Haven't seen one of those before, but it sounds promising. Tried the capacitance type sender, couldn't get it to work right. Went back to orig float type that only works when it wants to.
Edit: Just noticed it says the output is PWM which I assume is Pulse Width Modulation. Doubt that will work with my current resistance type fuel gauge.
Here you go, and thanks for the kind words, but i’m not. My bulb is dim, but it does work.
https://www.holley.com/products/gaug...parts/19-250-1
It says it works on classic gauges?
My gauge last time out decided to stop workinh
have not had the mobility to get into it to see of its an easy fix of if sender died
gaffrig makes a gauge that looks like my dash gauge
It did mention highly reflective tanks could be an issue
Mine is alum...its pretty reflective ....at least the outside 😁
the instructions do mention a gauge a few times
I net for me a 1988 gauge is no go
I supect mine are gauge, sender package
- Easy to program the level of any tank and electronic gauge - does not work with OE style gauges that utilize an ohm only input
CENTROID PRODUCTS - Electronic Fuel and Water Senders
They make the senders for pretty much every retailer and are about half the price
