Imco -2 lower question
How manny rpm would you pick up wen u put on a -2 lower on a single 30 V bottom with a pad 6500 lb boat 502 500hp 1.5 gear ratio bravo 4 blade prop lower is about 4 inches below pad now. TIA
I agree with Griff. You can install an IMCO SC -2 lower but you'll probably end up with a 1-1.5 inch spacer. I do like the IMCO SC lowers though, very little drag.
i put a 2 inch shorter sportmaster on our 25 foot thunder and lost the fun of overtrimming and winding it to the moon nothing sounds like a na bigblock wound up to 7000rpm it still slides on plane with no effort, it was more fun with it deep
