Swap U-joints or buy new extended shaft yokes >
Old 02-23-2026 | 09:31 AM
bn
Default Swap U-joints or buy new extended shaft yokes
I currently have XR drives with IMCO extension boxes. The XRs are the older style with the large u-joints and the coupler yoke has the extended shaft for the extension boxes. I’m switching to the new style swept back XZ drives with the smaller u-joints. Is it an option to swap out the smaller u-joints that came with the XZs and install the large XR u-joints on the XZs so I can reuse the extended shafts? Or is my only option to buy new yokes with the extended shaft that will fit the smaller u-joints that came on the XZ drives?
I know the newer XRs have the smaller u-joints as well so I’m guessing that I’m not the first person to run into this issue, but I couldn’t find any threads on this topic.
bn is offline
Old 02-23-2026 | 10:17 AM
There are u-jounts that have different size cups for this reason. As long as you know the diamater of each set of cups and the lenght from cup ends you can have a jount matched up at a bearing/belt/pulley distributor or a driveshaft shop.
To get new shafts is expensive opposed to a semi-custom u-jount, prices on IMCO extention box shafts is $$$.
LakeBoat4 is offline
Old 02-23-2026 | 02:48 PM
As mentioned I believe there are 3 different sizes out there. Why are you going from XR to XZ?
CheckmateScarab is offline
Old 02-24-2026 | 11:44 AM
bn
From what I’ve learned, the only difference between the XR and the XZ drives is the upper gear set. The X/XZ gears apparently last longer since they are not prone to pitting, but will break easier if you frequently get a lot of air or like doing hole shots. We boat on inland lakes and get on plane easy so that will not be a problem.
I appreciate the replies. I’m still wondering if I can just swap the entire u-joint assemblies without having to replace anything else?
bn is offline
Old 02-24-2026 | 03:10 PM
Easiest way would probably be to find a combo U joint.
Griff is offline
