8.2L engine knowledge
I'm looking at another boat that has 8.2 l, 380hp catalytic engines. These engines have closed cooling and have been running in freshwater. Question...
1. How many hours should an engine have before a top end is performed?
2. When should the exhaust manifolds be changed?
3. What do you have to do to make a 8.2L, 380 HP engine 430HP? Computer flash?
these engines will run well over 1000 hrs before major overhaul. Manifolds, IMO, are dependent on where it's run. I just traded my 496 with 550 hrs. on it and never did the manifolds. I just inspect them.
I think there's more to it than a flash. I wanna say cam and other stuff....
Not at all the same engine, but the only real differences between the 496MAG and the 496HO is the cam and the ECM flash. I'd imagine it's the same with the 8.2.
Thanks. Brad.
Here is some good and bad about these engines, dont know what year engines you are looking at, maybe mother Merc have these fixed ?
New 8.2L Mercruiser engine
yeah...these engines are not easily tinkered with. That why I think trying to make a SO to an HO is not worth it.
