Bravo Gimbal - Re-designed Water Intake Hose? >
Old 04-17-2026 | 01:13 PM
Default Bravo Gimbal - Re-designed Water Intake Hose?
It appears the have re-designed this hose.
Has anyone installed one of these? Just curious how well it went in, can it be done with the motor in?
I installed new ones (old style) when I rebuilt my transom assemblies, but one looks like the SB side is collapsing causing low water pressure and higher than normal temp. I can't remember if they were OEM MerCruiser or aftermarket. (lesson learned if not) I'll have to pull them apart to replace.
PS... shout out to Jeff32, I found a thread from 2007 where he had a similar problem with the hose collapsing that lead me to look under the drives with a flashlight.
Shah Mat is offline
Old 04-17-2026 | 08:05 PM
Reminds me of the BMW cooland hose attachment system. Never had one fail...with ultra high coolant temps they run...but would still prefer the hose/barb with 2 clamp system.
BMW water Pump.
Tartilla is offline
Old 04-17-2026 | 09:26 PM
used that kit a couple of times, works great
boatnt is offline
Old 04-19-2026 | 11:59 PM
Does the hose fitting clip on?
Tartilla is offline
Old 04-20-2026 | 09:22 AM
are you asking about the hose inside the boat? mine glamped on,
boatnt is offline
Old 04-20-2026 | 11:03 AM
Does that flange go on the "wet" side of the gimbal housing and squeeze the rubber bushing to tighten it into the space creating a waterproof seal?
I'm trying to figure out what holds the plastic pipe in the gimbal housing and seals it.
Shah Mat is offline
Old 04-20-2026 | 11:20 AM
Duh, the next product picture on the website was the instructions. I guess it's just pressed in??
Shah Mat is offline
Old 04-20-2026 | 11:37 AM
SB
https://www.mercruiserparts.com/bam/...99628/28199855
SB is offline
Old 04-20-2026 | 12:11 PM
Shah,
I did this on my drive assembly last winter, during my engine rebuild. It all went well enough, but I seem to remember getting the hose through the hole in the transom plate was a significant PITA, and you'll need a tool to tighten up the "nut" that holds the hose in place.
Thanks. Brad.
Brad Christy is offline
Old 04-20-2026 | 04:13 PM
Shah,
Thanks. Brad.
yes, need special tool
boatnt is offline
