Python 24’ Prop Help >
Python 24? Prop Help
Old 05-26-2026 | 06:54 PM
Default Python 24’ Prop Help
I have a Python 24/7 with a 502 Mag Mpi. What are 4 blade props you guys recommend? Currently has a Bravo FS but i need more bow lift. Or should i just have the FS cupped?
R1racing is offline
Old 05-27-2026 | 08:58 AM
When I had my 24x7 (Sunsation Rocket) the best prop I found was the Mercury Rev4... It have me the best now lift, matched top speed of other props I was running, plus super easy getting on plane, and best mid range speed but a decent amount... Rev 4 has a good amount of cupping.
I'd definitely recommend trying on before messing with yours... Do a search in here, there's a bunch of threads on 24x7 props.
What pitch are you now and what speed & RPM are you getting
cdaniel525 is offline
Old 05-27-2026 | 11:20 AM
Currently running a 24p Bravo FS. 4800 rpm, 72mph. porpoising starts when approaching top speed (67+) Tried a few things ive ready about trim on these hulls and nothing works. I believe i need more bow holding capability.
Alot of searching points to the Mirage, but id like to stay with a 4 blade. Then it seems to point to a Bravo or Rev 4
R1racing is offline
Old 05-27-2026 | 11:26 AM
Rev 4 definitely had more bow lif - it also eliminated chine walk I was getting... Not sure if it'd help with porpoising but if the bow lift eliminates it, the Rev 4 should work.
Old 05-28-2026 | 06:03 PM
Typically porpoising is from a loss of bow lift when it reaches a certain bow up angle. Stals out..then lift is regenerated until it stalls again. You may have too much bow lift, or something is causing the lift to fail when it achieves the bow up angle.
Tartilla is offline
