200mph
Old 12-30-2002 | 04:12 PM
MavFlyBy
Default 200mph
Hello,
I have a question here, besides all the safety stuff what is really needed for a V bottom or Catarman hull to reach 200MPH? Does anyone have any links to boat descriptions that have done it? I know that it is probably not the safest thing to do, but to me that would be an incredible goal to reach. Any comments/ideas would be appreciated.
Thanks,
Lance
Old 12-30-2002 | 04:16 PM
riskybusiness
All you need is a bottomless checkbook
Sorry. Not very helpful, but had to say it.
Old 12-30-2002 | 05:02 PM
MavFlyBy
lol I know that much :-)
Old 12-30-2002 | 05:10 PM
Devil's Island
How about an 80 MPH boat with a 120 MPH tail wind?
Seriously, turbine power is the only thing that will get you to the promised land without rebuilding 4 piston/pushrod internal combustion engines after each 200MPH stint...
ccarloss's Avatar
You could give these guys a call Callan Marine I believe they have been over 200mph.
ccarloss is offline
Old 12-30-2002 | 05:17 PM
tachyon's Avatar
Even with turbines you won't see a vee run anywhere near that. You'll run out of bottom long before hp. A tunnel hull is the only way to do it.
tachyon is offline
Old 12-30-2002 | 05:39 PM
Ron P's Avatar
Enjoy the show
It takes two 1850hp turbines for Jetset to reach into the mid 190s.with a 40' skater. Also it takes 20,000 RPMs.
Ron P is offline
Old 12-30-2002 | 06:14 PM
HyperBaja's Avatar
Originally posted by catmando
It's very doubtful that a V bottom will ever reach 200. The hull cannot overcome the hydrodynamic forces acting on it. Take the fastest V hull out there(whatever that is), put two 3000HP turbines and Arneson Drives on it, and it MIGHT get there, but I wouldn't want to be in it.
A V hull is not stable at those speeds, which is why all the speed records above 150MPH have been set by cats and three-point hydros.
But maybe I'm talking out of ignorance here. Somebody's bound to know.
What would need to be done to that arneson??
HyperBaja is offline
Old 12-30-2002 | 06:36 PM
tachyon's Avatar
Alot will depend on your prop rpm. There are different ways to get to those speeds. Its a function of pitch and rpm. Spinning a high rpm with lower pitch is easier on the driveline but tough on bearings. Running a longer prop will get you there but either requires stressing the driveline or alot of run in to make the power slowly. I'd recommend a shaft drive - Arneson derivitive with a rudder at these speeds.
tachyon is offline
Old 12-30-2002 | 07:59 PM
Steve 1's Avatar
Personally I do not see any problem at all with a Piston Powered Cat going over 200.
Steve 1 is offline
