4" Exhaust Tube Best Price? >
Old 01-03-2003 | 05:41 AM
Default 4" Exhaust Tube Best Price?
Who has the best price on 4" rubber exhaust tube?....Thanks, Fred
fred is offline
Old 01-03-2003 | 06:18 AM
Mbam's Avatar
Offshoreonly Advertiser
How much do you need?
Mbam is offline
Old 01-03-2003 | 02:31 PM
I haven't made final measurements yet but I will need 4 pc's for BBC with center risers and TRS drives with BW transmissions, 4" ID.... Fred
fred is offline
Old 01-03-2003 | 11:25 PM
Audiofn's Avatar
Charter Member #232
Fred I have the same set up and I used stainless pipe on mine btwn the riser and the tip. It looks MUCH better and if you get a little dry on the exhaust it does not burn up. I have lots of pipe left if you are interested give me a call and I will hook ya up. (978) 985-0639
Jon
Put your best foot forward!
Audiofn is offline
Old 01-04-2003 | 02:24 PM
Mbam's Avatar
Jon's approach is the best, looks really great and lasts much longer.
Mbam is offline
Old 01-05-2003 | 08:50 PM
hey audio fn can you build transisions(spelling?)
carreraboat is offline
Old 01-05-2003 | 09:42 PM
Audiofn's Avatar
Charter Member #232
I had it done for me.
Jon
Audiofn is offline
Old 01-06-2003 | 08:08 PM
who did you use can you just buy the pipe and have someone local do it? tig?
Old 01-06-2003 | 08:19 PM
No welding....you couple and clamp the rubber 4" hose at the riser and the tailpipe with the stainless pipe between....Fred
fred is offline
Old 01-06-2003 | 08:41 PM
Audiofn's Avatar
Charter Member #232
Fred he is talking about having bends in the pipe. I have a friend that is a REALLY good welder and he welded it for me. He used a Tig welder and before he welded it he made sure it was SUPER clean, put a plug in the ends and then filled the pipe with gas. I guess this gave beter penetration on the weld. What ever it was the welds are PERFECT.
Jon
Audiofn is offline
