Removing Fuel Rail >
Removing Fuel Rail
Removing Fuel Rail
Old 01-05-2003 | 02:59 PM
Elite Marine's Avatar
Default Removing Fuel Rail
How do you remove the fule rail from the intake manifold on a 502 MPI injection set up? I've removed the (4) small bolts, but the whole unit barely budges. Is there a secret? Please let me in on it if there is.
Elite Marine is offline
Old 01-05-2003 | 03:24 PM
FindMe
Squirt a little WD40 at the base of all the injectors and give them a twist to free them up in their bores, then pull evenly on one side in the direction of the injector holes, NOT straight up. Sometimes a bit more twisting from one end to the other while pulling will help. Because of the angle of the injectors after one side is out, the other side is easier. Don't be afraid, there is nothing but the orings holding them after you have removed the 4 bolts... Are we havin fun yet? lol
Old 01-05-2003 | 03:36 PM
Thumbs up Going to try
I'll try it right now. I assume you'll replace the broken injectors if it doesn't work right?
Old 01-05-2003 | 04:00 PM
Default Success!!!
Thank you Findme. It worked just as you described.
Old 01-05-2003 | 10:40 PM
FindMe
Whew.... lol you had me worried about upgrading your fuel system for a minute... heh heh heh
Glad it worked as described, your one step closer.....
Rocko C
2
06-22-2008 07:47 AM
Griswald
6
02-11-2008 07:14 AM
vincentblack
2
12-17-2006 02:27 AM
kennyo
4
08-11-2006 03:03 PM
TROUBLE MAKER
13
01-16-2006 06:28 PM
