oil drain/fill plug , alpha/bravo , are they the same????
Is the top oil fill/ drain plug on a alpha 1 the same as a bravo???
I am looking to get a oil reserve canister that taps into that location , but it says its for a alpha . is there a difference ????
I do not think you are talking about the lower oil/drain plug (67892a1) which believe it or not is the same on Bravos and Alphas. Even though there in different places. Alphas has it in the gear housing the Bravo on the bearing carrier (behind the prop).
The Alpha and the bravo have a different upper over flow plug:
Bravo: 67892a1
Alpha: 79953q2
I believe the thread is the same but go to a parts dealer and check!!!
Bravo: 67892a1
Alpha: 79953q2
