Difference between 500efi and 575Sci >
Old 01-16-2003 | 12:49 PM
BAJA WILL's Avatar
Registered User
Default Difference between 500efi and 575Sci
Looking to learn some here, What is the difference between these two besides the 256cid Holley/ weiland, and compression ratio?
Are their differnt internals, heads, cam, springs,??
BAJA WILL is offline
Old 01-16-2003 | 01:34 PM
traviss's Avatar
here are the specs for the 500 EFI
http://www.mercurymarine.com/hp500_efi_-_470_hp
and the 575
http://www.mercurymarine.com/hp575_sci_-_550_hp
This might help alittle
Travis
traviss is offline
Old 01-16-2003 | 03:17 PM
BAJA WILL's Avatar
Registered User
Traviss,
I went through the specs and only diff it lists is as follows
575= TBI, comp 7.50:1 and weiand 256, 92 oct required
500= MPI, comp 8.75:1 87 oct required
I am really curious is the blower the only differance?? their has to be more to justify the cost??
Old 01-16-2003 | 03:39 PM
Boating magazine had an
article on building the 575,
i will try to find it when i get home
tonite, but some of the differences
I do recall were: 575 flat tappet
hyd. cam, the already mentioned
compression difference, and shorter
connecting rods ???
With mercury marine horsepower
is exponential with $$$$
jt
JaayTeee is offline
Old 01-16-2003 | 08:16 PM
mcollinstn's Avatar
Oh yeah, the oil filter screws on an additional 1/8 of a turn on the 575. That oughta be worth some $$.
mcollinstn is offline
Old 01-17-2003 | 09:36 AM
rjcardinal's Avatar
The 575 is a hand built blueprinted motor while the 500EFI bottom end comes preassembled from GM powertrain like the rest of the black Merc motors. Im sure they justify some of the cost from this fact. Still pricey though.
Ron
rjcardinal is offline
INDY27
4
07-31-2008 12:25 PM
Fever575
Do It Yourself, Boating on a Budget
4
07-31-2008 11:59 AM
performancemary
Powerquest
13
05-26-2005 12:30 PM
performancemary
05-13-2005 02:31 PM
aTX427
14
05-21-2004 07:43 AM
