hp 500
Old 01-20-2003 | 04:16 PM
tbone
Default hp 500
what octane gas do you use in your stock HP 500??
Old 01-20-2003 | 04:21 PM
Dock Holiday's Avatar
Charter Member #34
Stock 2002, 500 EFI's
Dock Holiday is offline
Old 01-20-2003 | 04:53 PM
later's Avatar
Missed you last thursday at our first St Louis oso gathering
Later
Dave
later is offline
Old 01-20-2003 | 08:21 PM
Sydwayz's Avatar
Forum Regulator
By the book, 87 in 500 EFI
Sydwayz is offline
Old 01-20-2003 | 09:01 PM
BAJA WILL's Avatar
Registered User
89 oct on 500efi 2001 model, 178 hrs runs great.
BAJA WILL is offline
Old 01-21-2003 | 06:09 AM
SteveS's Avatar
87-89 in my EFI, it does not like anything higher.
SteveS is offline
Old 01-21-2003 | 06:42 AM
bajadude's Avatar
89 in 1999 HP500s (150 hours), no problems.
bajadude is offline
Old 01-21-2003 | 09:32 AM
the higher the octane #....the less btu it has....in short, run 87 in that engine....
racers...yeah we also pay near 4 bucks per gal to go slower!
audacity is offline
Old 01-21-2003 | 10:54 AM
jawbreakerkid's Avatar
hey JJ, maybe that is why you are going 7mph slower!!! LOL!
jbk
jawbreakerkid is offline
Old 01-21-2003 | 01:01 PM
later's Avatar
maybe its all the additional weight of the new paint what kind of rpms are you spinning if its the same and your using the same props maybe its your speedo, and if your using a gps now and werent then, then maybe you havent lost the 7 mph and in that case go back to your old speedo to find it.
it sounds as if you change quite a few things and its just a matter of dialing back. did you change props gears etc.?
Later
Dave
later is offline
