Labbing for 302 >
Labbing for 302
Labbing for 302
Old 01-22-2003 | 07:39 AM
Shooter's Avatar
Charter Member #300
Default Labbing for 302
Hey Guys,
I'm about to contact Darin at Houston Prop. to clean up and lab my Mirage 25 plus's that found some crab traps before I bought it last summer. Who out there has a 302 and had similar props labbed. I hear HP will stand behind their props but I want to avoid back and forths. I'd rather get them right the 1st time. I have had Bravo 1's labbed before on blown singles but this is my first twin. I have 502 MPI Mags.
Any 302 owners out there... I would guess a 29 Outlaw would be somewhat similar.
Shooter is offline
Old 01-22-2003 | 07:57 AM
My boat is similar to yours in terms of size, weight, and hull. Bronson Hill did mine and I'm happy. I was able to go from unlabbed 25's to labbed 27's which of coarse made me faster. Lots of back and forth with Hill though. Mainly because they made me try 4 blade props before the 3 blade.
Can see 78mph on gps with the 27's (496HO's)
29 OUTLAW is offline
Old 01-22-2003 | 09:08 AM
GAMEMAN
Had a 97 29 Outlaw with 502s 27 mirage plus was the way to go put in 500efis 27 mirage still the best but never had either one labbed. Where are your rpm with your 25s, 4 blades are always slower more blades more drag. Now i have a 33 with labbed mercury props that is my suggestion no back and forth and does what they should, on the down side if you even look at a crap trap with a mercury labbed prop it will ding it they are very very thin.
Old 01-22-2003 | 09:34 AM
Shooter's Avatar
Charter Member #300
I am turning about 4800 or so depending on the day. The gauge says 77 - yeah right. No crab traps by me in Jersey, just some mud. Boat runs prettty good with the 3 blades. I know the 4's have a more poisitive effect on cruise, but as long as I don't stomp on the throttle, no problems.
I'm used to blower motor and I have stock now and want to keep it that way so I don't want to get a slower prop if I don't have to.
Shooter is offline
Old 01-22-2003 | 10:12 AM
If your only turning 4800 now it might be a stretch trying to go up to a 27. With stock 25's I was turning 5100+. With the Hill 27's I'm still turning 5000+.
Old 01-22-2003 | 11:37 AM
Advantage's Avatar
Shooter, I have a 29 Outlaw with 454 Mags. I had my 25 pitch 3 blades labbed at York Propellers. Because of my higher x, I was already pulling 5,000+ rpms. He cupped, repitched, and blue printed my props to a strong 26 pitch. I now pull 5100 rpm's and 2-3 mph more.
Advantage is offline
Old 01-22-2003 | 08:25 PM
GAMEMAN
I agree with 29 outlaw if your tach is correct I don't think you could pull 27s labbing the 25s should increase speed and give you aprox 300 rpm.
Old 01-23-2003 | 10:34 PM
HOUSTONPROP's Avatar
Default Re: Labbing for 302
Originally posted by Shooter
Hey Guys,
SHOOTER !!!!!!!!!! I will thin the props out like a Mercury labbed prop super thin/This will do the job/just dont hit anything.Thanksfor the Business and it will be backvery soon ,
HOUSTONPROP is offline
masher44
Prop Talk
2
10-03-2007 05:41 PM
Rebel_Heart
Prop Talk
9
07-06-2007 09:27 AM
bcarpman
Prop Talk
1
04-15-2007 04:50 PM
IRONMAN
Prop Talk
2
06-06-2005 10:30 AM
Shooter
Baja
5
11-01-2002 08:09 AM
