Help with mechanical Mercury Racing trim indicators >
Old 01-26-2003 | 02:44 AM
skygod's Avatar
Default Help with mechanical Mercury Racing trim indicators
My starboard drive indicator stops indicating at about 3/4 up even though the drive will actually continue to trim all the way up/out. Any help? The other drive and 2 tab indicators work normally.
Again they are mechanical indicators. Thanks!
Baja History
2000 29 Outlaw 2x454 mags (sold)
2000 25 Outlaw 502 (moved up to 29 OL)
1998 232 Islander 7.4 (got the 25 OL)
Tow Rig
04 Excursion EB PSD 4x4 6" lift 35's
MY PICS: http://community.webshots.com/user/skygod73
skygod is offline
Old 01-26-2003 | 07:37 AM
Mbam's Avatar
Offshoreonly Advertiser
The cable is probably bound up, how old is it?
Mbam is offline
Old 01-26-2003 | 07:46 AM
GO4BROKE's Avatar
I've had that happen from sand jamming the mechanism.
[img][/img]
GO4BROKE is offline
Old 01-26-2003 | 08:42 AM
Audiofn's Avatar
Charter Member #232
Sounds like a bad cable to me. Also make sure your springs did not fall off the back side of the indicator pannel (some have them, some do not), but there is a BID one (spring) in the drive so that is NOT likely but worth the look. I would replace the cables with the ones from Gaffrig if you can as they seem to last a long time and bend real nice, just make sure that they will work with your through hull fittings and what not.
How is it going by the way? New Kids all healthy I hope
Jon
Put your best foot forward!
Audiofn is offline
Old 01-29-2003 | 01:24 PM
skygod's Avatar
They came with the boat, 2 years.
Where should I start, behind the indicator?
Jon, the kids are almost 3 and 2. They are doing well thanks for asking. How is everything for you?
Carl
Baja History
Tow Rig
skygod is offline
Old 07-07-2017 | 12:45 PM
I am having the same problem with my Mercury Racing mechanical drive trim indicator. I'd like to take it apart to check for fouling or lubricate the cable; but, I'd like to have a manual to reference. Can't tell you how many times I've taken things apart only to have things either fly apart or not go back together. I can't find a parts diagram or manual anywhere. Anyone have one they can post? Boat is a 2000 Baja 25 Outlaw.
Thanks in advance.
Hot Tub is offline
Old 07-08-2017 | 01:08 AM
Diagram Genuine Mercury & Mercruiser parts. Actuator Kit(846063A 1)
Griff is offline
Old 07-18-2017 | 07:15 AM
Thanks Griff. Do you, or anyone else, know if the cable from the drive actuator to the helm gauge can be removed from the sheath for cleaning and lubrication? I hate to think about having to replace the whole thing.
Hot Tub is offline
bigmotor
2
08-11-2008 07:39 PM
Inspector
Wanted
3
05-19-2008 04:05 PM
boatnt
Wanted
3
01-24-2008 11:58 PM
Full Force
3
09-10-2007 08:58 PM
VelocityMark
04-02-2003 04:05 PM
