belching fluid >
belching fluid
belching fluid
Old 01-29-2003 | 01:01 PM
onehotcitygirl's Avatar
Default belching fluid
recently after running semi hard for about two hours I have noticed that a considerable amount of sterndrive fluid has belched out of the fluid reservoir -- any ideas as to why would be appreciated -- this last summer the engine was rebuilt and drive pulled and fully serviced
onehotcitygirl is offline
Old 01-29-2003 | 01:26 PM
The drive lube got hot!!!!!! and expanded. Also, probably some air in the drive--which expands more than the lube. Get a drive shower to keep temps down.
Griff is offline
Old 01-29-2003 | 01:58 PM
drive seals are leaking,better get it fixed soon drives can be ugly when they let go.Good luck
Dixie Doug is offline
Old 01-29-2003 | 10:46 PM
mopower's Avatar
Toxic FORMULA
What Griff said
Try a Simrek shower...the cheapest and best cooling
mopower is offline
Old 01-30-2003 | 06:29 AM
you may have drive issues! lowering the drive tmp 50deg with a drive shower is not going to resolve that. needs further investigation.
audacity is offline
Old 01-30-2003 | 06:41 AM
KAAMA's Avatar
Audacity, what are some of the reasons or "drive issues" of why the drive lube would be overflowing the resevoir? Thanks
KAAMA is offline
Old 01-30-2003 | 06:47 AM
HUGE air pocket...water....overfilled....cracked rez....combination of.
take the top cap off the drive. inspect the bearing and the race....see if it was starved of lube or had excessive heat present. this will also give the current oil level...if you can't see any??...pull the back cover....if none comes out then it was way underfilled...drain the oil and inspect it as well....
i hate you KAMMA...making me type!
audacity is offline
Old 01-30-2003 | 06:49 AM
Offshore Addiction
seals are leaking and its ingesting water and pushing the fluid upward,it'll look like clean fluid at first but will become a milky nasty fluid soon,need to pull the drive and pressure test it.......
Old 01-30-2003 | 07:56 AM
KAAMA's Avatar
Talking Joe you're too funny---made me laugh!
I knew that would stir you a little----you need some practice on good typing skills!
KAAMA is offline
Old 01-30-2003 | 08:01 AM
no...i really don't!....i'm a very lazy man....
audacity is offline
