Filling transom holes
I'm moving the location of my water pick-ups and need to fill two 1-1/4" holes in my transom that are below the waterline. There are also four small 1/4" holes from the mounting bolts.
What is the best way to fill the holes?
Thanks for any help, Jeff
I would take a 1 1/4" hole saw and cut out a few pieces of 3/4" or 1" plywood. I don't know if you can find a 1 1/4" dowel. Use the plugs of wood to fill in the holes in the boat. Leave about 1/4" space between the outside and inside of the hole. Fill the rest with fiberglass, fill the voids with fiberglass bondo, sand down and bevel outwards. Then re-gel.
