Removing Old Name from Stern >
Old 02-12-2003 | 07:25 PM
GLH's Avatar
GLH
Default Removing Old Name from Stern
I need to get this name of the back of my new boat it is painted over all the finishes and has already started fading and coming off. I did a search here and got Oven Cleaner, Nail polish remover, acetone and the works. Anyone can give me a task sheet to follow and a degree of difficulty for an idiot like me apart from.
1. Take it to the local goofy fiberglass man to do it.
2. Pay him for his work.
I am actually very familiar with #2 on the list and would like to see if I can actually do any form of a task that involves dexterity of any kind.
Thanks in advance for your help.
G.L.
GLH is offline
Old 02-12-2003 | 07:31 PM
I've been told it's " bad luck"
to rename a boat
JaayTeee is offline
Old 02-12-2003 | 07:39 PM
GLH's Avatar
GLH
I already have the "Offical Denaming Ceremony Process" to follow I just need the chemical process!
GLH is offline
Old 02-12-2003 | 08:55 PM
Rookie's Avatar
Lightly scrub it with a PLASTIC pot scrubbing pad (propelene pad), or the softest scotch brite pad available, I think white. soaked in acetone (fingernail polish remover). The pad will give it a little abbrasion w/out scratching the gelcoat. Something that you can still buff out the swirl marks later.
If the acetone doesn't touch it step up to paint thinner. Check first in an inconspicuous spot to see it discolors, but it looks like it is on white.
Remember to keep a towel handy so you can keep it from running down the boat. You will leave a ghost image of the name, a good rubbing compound, and some elbow grease should remove it.
just my thoughts Jason
Rookie is offline
Old 02-12-2003 | 10:25 PM
Big E
to rename a boat
My buddy re-named his boat and had nothing but trouble with it, I heard it was bad luck too. I didn't change the name on mine, call me superstitious because I am.
Old 02-12-2003 | 10:53 PM
"easy off" oven cleaner
PROFILE is offline
Old 02-12-2003 | 11:46 PM
Audiofn's Avatar
Charter Member #232
I am leary of the cemical stuff. I would get 600 grit sand paper on a rubber block and wet sand it off and then buff it out again. This will do two things. One it will get it off. Two it will remove the the raise were the letters were so hopefully IF you are lucky you will no longer be able to see were the letters used to be.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-13-2003 | 06:37 AM
GLH's Avatar
GLH
Thanks for all your help.
Regarding the "luck" factor I try rely on luck to a minimum but for the skeptics.
http://www.boatus.com/goodoldboat/naming.htm#denaming
http://www.boatus.com/news/namegame.htm
GLH is offline
Old 02-13-2003 | 08:45 AM
Easy Off oven cleaner. I've done it on 2 boats, no problems.
Gary
Gary Anderson is offline
Old 02-13-2003 | 04:09 PM
Baja Bopp
How long do you leave the oven cleaner on?
Gene
