need to go faster???? help >
Old 02-18-2003 | 02:32 PM
baja240-1
have 1991 baja 240 es wondering how I can make it faster without spending lot fo money??????????
Old 02-18-2003 | 03:01 PM
THEJOKER's Avatar
Wink try this...to start with
Try getting some weight out of the boat.
Make sure you prop the boat correctly.
Blueprinting the bottom could help.
Check your drive alignment - very important.
I hope this helps you - BH
THEJOKER is offline
Old 02-18-2003 | 03:02 PM
HyperBaja's Avatar
What size motor now?
HyperBaja is offline
Old 02-18-2003 | 03:08 PM
mr_velocity's Avatar
I agree with BH.
Do the free things first (weight, alignment)
then
Blueprint the bottom
then
add power
then
reprop.
mr_velocity is offline
Old 02-18-2003 | 03:28 PM
Default Re: need to go faster???? help
Make a boat go faster WITHOUT spending a lot of money?????
Thats a good one
Griff is offline
Old 02-18-2003 | 06:14 PM
Waterfoul's Avatar
Gone Fishin'
By 240 es, I'm assuming you are talking about the old 226 that was changed to the 240 es when the coasties decided to include swim platforms. If so, all mentioned above is a good place to start, but will only get you so far. We need some more information.
What power is in it now (be specific)??
What prop are you running??
Where do you usually boat?
Define "not much money" for us.
Like Griff said, there really isn't much that's free about more speed. When you've thrown our all the extra sruff, aligned everything, etc... start with heads.... Clean them up (the combustion chambers), get a good valve grind, and some port work. Also, don't underestimate how much valve reliefs can give you more torque an hp, they help your motor breath better (JimV on this board has dyno proof that on a slightly more than stock motor, it will add nearly 30 hp!!). If your running a magnum motor, your intake is pretty good but you might want to up your CFM. A good Holley double pumper.....750 or so, should help out. Exhaust would be the next thing......stock exhaust will handle up to about 400 hp o.k. but over that you will need better exhaust. I've been thru all this before. Twice. Feel free to email me if you want. If you want to spend a little more money, a cam and lifter change will really wake things up. If you can do any of this yourself (the only way I can afford it) you will be surprised how "cheaply" you can do this as compared to paying a shop to do it for you.
Mike
Waterfoul is offline
Old 02-18-2003 | 07:57 PM
Mate 229's Avatar
Waterfoul hit it, I had a Checkmate 229 with 454 Mag. Added Holley 750DP, Edelbrock intake, Cam, Roller Rockers, Rect port heads, Crane Dist and MSD box. Made 475HP and was extermely reliable and strong setup. Not all that expensive to do either. Exhaust was next but sold it. Ran well with stock Manifolds though. Look through classified section some good deals on parts and complete engines. Good luck
Mate 229 is offline
Old 02-18-2003 | 08:39 PM
rbtnt's Avatar
Sharpen the transom edge at the bottom and check for a hook in the bottom. I've seen the "baja bounce" go away with a sharpened edge. Don't remove a hook if it has one without talking to someone who has done this type of work.
rbtnt is offline
Old 02-18-2003 | 08:47 PM
HOUSTONPROP's Avatar
well start with a little wax on the bottom and lab the prop/then get rid of those friends that don't kick in when boating will be glad to talk more in PROP TALK to see if we can make a difference? but need more info? motor/normal load conditions ect.
HOUSTONPROP is offline
fastedy
Superboat
24
09-29-2005 04:10 PM
HuntingtonBeach
Superboat
0
09-07-2005 09:23 PM
alter ego
Prop Talk
12
06-13-2005 07:43 AM
aero-offshore
36
11-29-2004 08:37 AM
36spectre
08-06-2003 11:54 AM
