Lubes?
Old 02-20-2003 | 09:43 PM
kathycool's Avatar
Default Lubes?
What't type of grease to use on couplers?
Also what type of oil for weiand blowers on 525SCs?
kathycool is offline
Old 02-20-2003 | 10:08 PM
mopower's Avatar
Toxic FORMULA
Engine couplers or trailer couplers In either case I use the blue water resistant marine grease ( same as wheel bearings)
Can't answer about the Weiand blowers ....I'm not blown
mopower is offline
Old 02-20-2003 | 10:17 PM
Mear Image
Mopower, Why did you order them Boost guages?
Mark
Now get back to work!
Old 02-20-2003 | 10:45 PM
mopower's Avatar
Toxic FORMULA
Mark,
SHHHHHHHHHHHHHHHHHHHHH....don't tell anybody
Time to go home
mopower is offline
Old 02-20-2003 | 10:51 PM
Mear Image
Oh, That's right.. I forgot! I meant What about those clocks you bought. Boost gauges, Silly me..
Mark
Good night..
Old 02-21-2003 | 03:45 AM
Default Re: Lubes?
Use the Merc High Performance gear lube in the blower. Same stuff that goes in the drive.
Griff is offline
Old 02-21-2003 | 03:48 AM
I should add, make sure you check both the front and back fills on the blower. They are completely separate. Change the lube out completely/as much as possible at least every 50 hrs.
Griff is offline
Old 02-21-2003 | 08:24 AM
kathycool's Avatar
Thanx for the info,
getting ready for spring
aTX427
1
04-14-2005 12:53 PM
