DesktopDyno users find my mistake >
Old 03-02-2003 | 03:00 PM
GO4BROKE's Avatar
Default DesktopDyno users find my mistake
I plugged in all the stock #'s for a merc 525sc, but I'm not getting the right power #'s. My stock 454 mag came within 1 hp of its rated power when I ran it on desktopDyno. Heres a summary:
Engine: 454 4.251"x4.000"
Heads: Stock Merc rectangular port cast iron
Compression: 7.5:1
Induction: [email protected]"hg, Weiand 177, belt gear ratio 2:1, 55% eff
Exhaust: default to Forced induction exhaust
Camshaft: Crane#132561 530/551 lift, 298,306 advertised duration, using seat to seat
[img][/img]
GO4BROKE is offline
Old 03-02-2003 | 03:46 PM
What results are you getting?????? WOT operating range is 4800-5200rpms.
Griff is offline
Old 03-02-2003 | 06:00 PM
GO4BROKE's Avatar
Desktop dyno horsepower estimates, stock 525sc:
4500rpms=444hp
5000rpms=486hp
5500rpms=510hp
Way low #'s. Ive had good results with other motors.
[img][/img]
GO4BROKE is offline
Old 03-02-2003 | 06:26 PM
I'm guessing that #'s at 5200 are probably real close to 500hp. Based on that the desktop #'s are only off by 5%. I don't think 5% is THAT far off. Could it be the blower efficiency # or the exhaust causing the difference????
I know puder had an engine with pretty close to 525SC specs and it dynoed at 550hp+/-. If I remember, he had a little more cam and comp ratio.
Griff is offline
Old 03-02-2003 | 06:30 PM
Scott's Avatar
Charter Member #30
CAM TIMING
@ .050
Try this instead of Seat to Seat
I'm guessing here so bare with me
Try This link
I have Steps & Bubbles!
Scott is offline
Old 03-02-2003 | 09:44 PM
mcollinstn's Avatar
I've never gotten useful numbers with Dyno2000 using .050" numbers. Seat-to-seat has been much closer to known figures for known setups. Don't know why, but this has been my experience.
mcollinstn is offline
Old 03-03-2003 | 05:03 PM
GO4BROKE's Avatar
Seat to seat has worked best for me, but I'll experiment to see what happens with the 525 simulator.
[img][/img]
GO4BROKE is offline
breenm
05-08-2008 04:16 PM
camptappakeg69
Active Thunder
5
05-31-2007 04:53 PM
Liberator21
4
07-05-2006 12:24 PM
bford1
Cigarette
2
10-06-2004 11:17 PM
GO4BROKE
7
10-22-2002 11:46 AM
