does anyone recondition trim pumps >
Old 03-02-2003 | 05:51 PM
Default does anyone recondition trim pumps
or is it cheaper to replace
SLINGSHOT is offline
Old 03-02-2003 | 06:16 PM
blown formula's Avatar
I don't know if any commercial outfit does it, but you can purchase individual parts for everything & get them from Mercruiserparts.com. I't sot of difficult to find the parts breakdown as it is not in the regular sections. You must look under some of the performance areas at the bottom of the list. I fixed several leaks in my pumps with parts ordered (new o-rings, screws, etc) They worked perfectly. Easy to do but a little messy.
Hydraulics really aren't that difficult unless you have to design a system. I'm sire many o-rings & seals could be purchased at a local hydraulics shop also cheaper, too. Many pumps are on ebay, but all at $200.00. O-rings are far cheaper!
blown formula is offline
Old 03-02-2003 | 06:46 PM
RUSSSR1's Avatar
does anyone offer a compleat rebuild kit for them? One of mine sounds like it is pumping air all the time. It does not react as fast as the other side that sounds normal.
RUSSSR1 is offline
Old 03-02-2003 | 08:36 PM
I replaced all of the O rings in both of mine. there was a lot of dirt and sludge in both of them. A thorough cleaning and new o rings will do wonders for them.
THRILLSEEKER is offline
Old 03-02-2003 | 09:33 PM
mcollinstn's Avatar
Once I bought a complete rebuild kit for an outboard pump. Had every gasket, oring, check valve, and the plastic manual override valve. Cost around $25. Took less than an hour to do the whole shebang. Don't know if a "kit" like that is available for the offshore pumps but it might be.
I've had 2 motors rebuilt as well (for about $25 each).
mcollinstn is offline
Old 03-03-2003 | 06:36 AM
Audiofn's Avatar
Charter Member #232
I take mine to my guy that rebuilds my Alternators. He charges me 80 bucks if I remember correctly. Seems to do the trick. New ones are like 350 bucks so as long as you did not really smoke it you should be ok. I would call around to you local alt. rebuilder.
Jon
Put your best foot forward!
Audiofn is offline
Old 03-03-2003 | 06:38 AM
merc no longer has the rebuild kits....sucks...i had to buy the complete pump...i hope this is a temporary thing..
audacity is offline
scottsumrall
5
09-02-2008 11:57 PM
CAPTAIN CHUCK
Drives and Lower Units
1
06-04-2007 09:53 AM
wstultz
2
01-23-2006 10:09 AM
Biggus
06-23-2003 08:23 AM
Gassticks
2
03-18-2002 08:11 PM
