How do you reclaim antifreeze at first start up? >
Old 03-03-2003 | 10:02 AM
Default How do you reclaim antifreeze at first start up?
I used the biodegradable antifreeze but still do not want to dump it in my yard when I start up for the first time this spring. Is there a way to reclaim it during start up? Most of my property's runoff leads to a stream that runs into the local resevoir.
Pure Energy is offline
Old 03-03-2003 | 10:08 AM
JUSTONCE's Avatar
For my through hulls I zip tie dryer hose over the pipes into a bucket and put a bucket under the bypasses.
JUSTONCE is offline
Old 03-03-2003 | 10:09 AM
Don't Let It Hit The Grass, My Buddy Did And He Still Can't Get Grass The Grow.... I Start Mine In The Driveway And Let The Sun Evaporate It Off The Cement.... Not A Good Answer But It Works For Me........
neu-rich is offline
Old 03-03-2003 | 10:11 AM
TEAMBAJA's Avatar
I'll probably take mine to moms house and start it in her driveway!
TEAMBAJA is offline
GLH's Avatar
GLH
It might be biodegradable but it degrades grass also. Neu-rich is right.
GLH is offline
Old 03-03-2003 | 10:23 AM
Allan4
This may be a little sloppy, but you can alwys drain everything into the bilge and put a bucket under thedrain hole on the transom, just fill a small pail a few times, then you can use it next year. Just be sure to test the anitfreeze before you use it again.
Old 03-03-2003 | 10:26 AM
OldSchool's Avatar
Pull it out of the driveway and start it in the street.
OldSchool is offline
Old 03-03-2003 | 10:45 AM
ChrisK's Avatar
Moderator
Go to a local car wash that has a hose or an appartment complex.... friends house? When I lived in NY we just ran it into the street from the boat and the motor home water system...
ChrisK is offline
Old 03-03-2003 | 12:23 PM
jrocket's Avatar
But Chris you live in Orlando now you know we dont have to do stuff like that
jrocket is offline
Old 03-03-2003 | 12:44 PM
ChrisK's Avatar
Moderator
I know... and its GREAT!!!!!
ChrisK is offline
