Gimbals & bellows >
Gimbals & bellows
Gimbals & bellows
Old 03-05-2003 | 09:10 PM
RUSSSR1's Avatar
Default Gimbals & bellows
I am relacing the bellows as I rebuild my gimbals my question is do I need the exhaust bellows or is there a blockoff plate or somthing of the sort that eliminats it when you are strictly through hull exhaust ? I was looking on BAM's sight in the Bravo parts section and saw a blockoff plate but not sure what it is. Any way if I do not need the bellows let me know.
Russ
RUSSSR1 is offline
Old 03-05-2003 | 09:14 PM
Tinkerer's Avatar
If all you have is thru hull exhaust now then you either have the block off plate now ( it is mounted on the inside of the transom ) or you have the Y pipe that comes up the transom with caps on them.
Tinkerer is offline
Old 03-05-2003 | 09:27 PM
RUSSSR1's Avatar
Tinkerboater,
Yes I have blockoff plate to the inside (no Y pipe). My question is can I eliminate the exhaust bellows?
RUSSSR1 is offline
Old 03-05-2003 | 10:20 PM
Tinkerer's Avatar
If you don't have any exhaust going through the drive the exhaust bellows should never have been installed in the first place. You may even gain some speed or help getting on plane.
Tinkerer is offline
Old 03-05-2003 | 10:40 PM
blown formula's Avatar
I'll answer the question simply.
Yes, you can leave off the exhaust bellows.
If using fresh water pickups rather than the drive for water, you can lease that hose off also. Only two other needed thats the drive bellows & shift cable bellows. That's all folks!!
blown formula is offline
RUSSSR1's Avatar
Nope through hull all the time. Do I need to block off the drive or is everyting left open, bar the plate on the inside?
RUSSSR1 is offline
Old 03-06-2003 | 12:37 PM
The opening in the drive will
act as a "vent" for the vacuum
area behind the prop hub,
(while at speed)
JaayTeee is offline
Old 03-06-2003 | 03:46 PM
RUSSSR1's Avatar
Good stuff, thanks guys. Open exhaust for a vent makes sence. One less bellows to F around with.
RUSSSR1 is offline
SLINGSHOT
04-06-2007 06:23 AM
Roger
02-05-2007 01:55 PM
articfriends
11
12-31-2006 02:28 PM
Quiet Storm
40
02-03-2005 05:21 PM
THRILLSEEKER
1
08-06-2002 12:52 PM
