Master Lube Oil Pre-lube
Great investment...purchased the 3qt model and am very happy with the performance. Easy to install and gives you piece of mind that the oil galleys are pre-lubed with no dry starts. System automaticly refills itself after every charge.
sheikman
sheikman
I just got mine and have not installed them yet. If you have a flat surface to mount the bottles on, do not order the installation bracket they will offer you. It is only an L bracket that is not needed.
Originally posted by dlbCheckmate
TTT. Anybody else have them ?
DLB, I don't know what engines you have but my 500efi's do not have a port in the remote oil filter to attach the system to and there is no way I can reach the ports at the back of the engine without removing them. I am going to try to have some ports drilled in the factory fittings and if that fails I will have to buy new fittings with the ports pre-drilled in order to install the system.
I think they are a great idea as it takes my engines about 15 seconds for the engines to sound like they are getting enough oil on a dry start. At $395 a piece I think that is cheap sompared to other things we do to try to extend engine or drive life!!
