Hydro- trim pump >
Hydro- trim pump
Hydro- trim pump
Old 03-10-2003 | 07:09 AM
Default Hydro- trim pump
Will the trim pump for the drives work on the K-tabs or are they a differant type pump ? They don't look the same, but the tabs have dual cylinders just like the drive trim. Anyone had any experiance with this? The drives are 1989 TRS, and the tabs are Merc's dual ram large Tabs 1989(keikhafer).
HOTROD2 is offline
Old 03-10-2003 | 07:22 AM
Mbam's Avatar
Offshoreonly Advertiser
They will work fine, just remember that the hi-pressure line on the pump = blue wire = down on the tabs.
Mbam is offline
Old 03-10-2003 | 07:28 AM
Thanks Mark, What is the proper way to bleed the air out of the system and what fluid sould be used?
HOTROD2 is offline
Old 03-11-2003 | 07:01 AM
Mbam's Avatar
You can use just about anything for fluid, the spec has changed over the years. ATF or 10-30 oil is fine.
As far as bleeding, I just run the tabs up & down a few times. I have never done anything to bleed the system, even though it is not a bad idea.
Mbam is offline
CNC
2
06-10-2006 07:36 AM
ratman
01-26-2006 07:48 PM
Poorsche
2
04-23-2005 06:48 PM
