502-Mag-Mpi Plugs >
502-Mag-Mpi Plugs
502-Mag-Mpi Plugs
Old 03-15-2003 | 10:10 AM
CAP071's Avatar
Default 502-Mag-Mpi Plugs
What spark plugs are you running (spark plug #) ? 2000 Stock 502 mag/mpi
CAP071 is offline
Old 03-15-2003 | 10:21 AM
Dennis Moore
Default A little bit controversial, but...
I have installed RV15YC4 Champion spark plugs gapped at .045 in many different big block powered boats and they work very well. The extreme projection on the nose gives the spark plug a wide heat range and the plug is designed for a larger plug gap. Thats good, because with the long spark duration of the breakerless induction ignition, a wider gap really lights off the air/fuel mixture well between idle and 5,000 rpm. They are very easy to find at automotive parts stores because they are such a common plug (probably Champions biggest seller).
Sincerely
Dennis Moore
Old 03-15-2003 | 10:29 AM
CAP071's Avatar
Thanks Dennis!
CAP071 is offline
Old 03-15-2003 | 04:20 PM
Macklin's Avatar
I had the exact same engine in my last boat. Had some problem with rough idling. Switched to Rapid Fire (#1 I believe) and MAN did they smooth the engine right out! Great acceleration and high end too.
Macklin is offline
Old 03-16-2003 | 11:04 AM
obnoxus's Avatar
Charter Member #1171
Same here ,,, rapid fire #1 ,,, cleaned up my transom to.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 03-18-2003 | 03:38 PM
powerguy's Avatar
Another vote for Rapid Fire #1. Did clean up the rear end on my 27' fountain. In addition to the plugs I have also set the timing to
12 deg advance (32 total advance), installed a K&N air filter , and added an EMI exhaust. These changes have really woke up the stock 502 carb motor.
powerguy is offline
Old 04-18-2004 | 06:24 PM
ttt
HPJunkie is offline
Old 04-18-2004 | 09:22 PM
CAP071's Avatar
3/15/03 post hoe'in huh
CAP071 is offline
Old 04-18-2004 | 09:52 PM
No but a friend of mine wants to know about advanceing timimg on his 502 mag so I sent him to the tech site and hioe he will see these. Greg
HPJunkie is offline
marwan
7
11-05-2008 01:22 PM
wballant
11
07-07-2008 06:01 PM
trawfish
4
12-12-2007 11:36 AM
R Addiction
3
08-15-2004 12:09 PM
Holy Smokes
12
07-17-2002 02:04 PM
