Sagging Headliner (272) >
Old 03-21-2003 | 06:38 AM
Default Sagging Headliner (272)
Need some advise.
Just went to Dallas and picked up a 96 Baja 272. The headliner is sagging in the cabin. What is the best procedurer to reglue to the hull?
Thanks, Jim
JimmyBaja is offline
Old 03-21-2003 | 08:01 AM
later's Avatar
take it out and have it replaced, headliners usually have a foam backing with the cloth material glued to them once it starts sagging the material has separated from foam and the foam is still glued to the bottom of deck.
later
later is offline
Old 03-21-2003 | 08:59 AM
obnoxus's Avatar
Charter Member #1171
Mine did it to,, just reglued and hasnt had a problem since.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 03-21-2003 | 09:05 AM
obnoxus
Did you have to pull the complete liner down to reglue? What did you use to re-glue?
Thanks, Jim
Old 03-21-2003 | 06:31 PM
H2Xmark's Avatar
the front headliner in my 29 outlaw was doing the same,[one above the bed] I removed one trim board on side, it had 3 screws that held it in place, one at the front, the middle and at the end, that is were the headliner tucks under on the sides, the backing board[foam] was still glued to the roof, like Later said, I toke a chance and used 3M super trim adhesive in a spray can, I used two cans, spray the back of the headliner and the contact surface {roof} let set a few minutes then starting at one corner I worked my way across, it looks great, so far so good
Mark
H2Xmark is offline
Old 03-21-2003 | 07:56 PM
garshev's Avatar
Thumbs down Headliners
W.T.F. is up with all these headliners?? Sure would p#$$ me of if it happened to mine!
garshev is offline
Old 03-21-2003 | 09:44 PM
SSComp's Avatar
Common problem. Nothing that 3m super won't handle assuming the foam is in good shape. 3m super is easy to work with although when you spray that much adhesive in such a little space you may come out quite buzzed. I suggest a fan, I had a headache later.
SSComp is offline
Old 03-22-2003 | 12:15 AM
obnoxus's Avatar
Originally posted by JimmyBaja
obnoxus
Thanks, Jim
No,,, just pulled the side trim strip off and shot glue where needed,,,, 3M trim adhesive,,, like H2X said
obnoxus is offline
Old 03-22-2003 | 08:09 AM
H2Xmark's Avatar
Bajalion had a great point, the fumes are BAD, get a cheap respirator, or mask, I used two fans and had the hatches open but it was still very bad, had to stop every couple minutes for fresh air
H2Xmark is offline
Diablo
Sonic
3
11-24-2008 06:36 PM
ApachePete
11-18-2005 03:47 PM
sleeper_dave
Fountain
16
11-13-2005 09:32 PM
amarket1
10-20-2004 10:06 PM
