Oil coolers
Old 03-26-2003 | 01:25 PM
BRUCE SEROFF's Avatar
Question Oil coolers
What type of oil coolers are you guys using? what do you recommend? BBC 600 + HP
Oil/power steering combination or separate. Im running one of those huge 4" imco coolers with PS and my temp is at 300+ degrees. the cooler may be shot. i dont know.
any advice ???
thanks
BRUCE SEROFF is offline
Old 03-26-2003 | 02:05 PM
Default Oil cooler
There are variable's, but a 3" x 12" in line cooler should easily handle 600-700 HP @6000 rpm. I use a separate small cooler for the PS. Are your water lines adequate?
BenPerfected is offline
Old 03-26-2003 | 02:53 PM
water lines are fine...water temp is good. I just think that this cooler is cotaminated or clogged or the backflow valve is stuck..who knows. just need to fix it...
thanks
Old 03-26-2003 | 05:49 PM
bob
Charter Member #40
While your checking things, make sure you are inputing your water from one end and the oil enters from the other end, so they flow in opposite directions.
bob is offline
Old 03-27-2003 | 12:12 PM
Cignificant's Avatar
I use the big Eddie's on my Cig Blower motors. One has the PS built in, the other does not. My temp never goes over 215 on either motor.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 03-27-2003 | 02:07 PM
Cig....
Is it safe to assume that you are referring to Eddie Marine coolers?
Old 03-27-2003 | 04:39 PM
DanB's Avatar
Charter Member #71
I 'm useing an Imco cooler with the built in 190* thermastat and the merc PS cooler seperate. About 575hp BBC
I actualy have a problem getting to run over 200* oil temp in the pan. Sounds like you have issues. Pull the cooler and soak it in paint thinner overnite. Then flush it and blow it out real good. Is it a new cooler? if so may have a blockage.
Dan
DanB is offline
dean51267
14
08-05-2006 12:07 AM
johnnyboatman
15
02-23-2006 01:21 AM
Shah Mat
13
11-30-2003 08:46 PM
lucky strike
1
10-03-2003 07:34 PM
