Aeroquip Socketless Hose >
Old 03-29-2003 | 10:53 AM
RLW
Default Aeroquip Socketless Hose
Has anyone used the Aeroquip socketless style hose and fittings? I was considering it for some fuel line runs. The fact there is no clamp, concerns me. Can't find any pressure ratings although fuel pressures are relatively low to begin with. I would like to get away from the steel braided due to cost and ease of use with the socketless.
Thanks, Russ
RLW is offline
Old 03-29-2003 | 11:28 AM
DanB's Avatar
Charter Member #71
I use them on my boat. Oil, fuel etc. They work great, the fittings cost as much but the hose is a little cheaper. Real easy to use. Cut hose, oil on fitting, slide it on. Ya got to push hard, you have to cut them apart. I figured if I wasnt gonna do everything I'd stick with a rubber hose. I like the way it looks better too. Jegs or Summit has the best prices for fittings. Aeroquip are the best but I have used Earls too.
Dan
DanB is offline
Old 03-29-2003 | 02:57 PM
RLW
Sounds good, DanB.
Thanks, Russ
RLW is offline
Old 03-29-2003 | 04:17 PM
Official OSO boat whore
Trust, the stuff is almost impossible to put on, so there is no way it's comming off.
Cord is offline
Old 03-30-2003 | 05:32 PM
Just lube it up when you put it together, and it is simple. We use it on race cars all the time without any problems.
RumRunner is offline
Old 03-30-2003 | 06:04 PM
formula31's Avatar
I have actually invented new swear words on the lines I made up for my oil system. They aint coming off. I didnt know that hose was rated for fuel though, is it?
formula31 is offline
Old 03-30-2003 | 06:21 PM
Yea, I figured that one out after I tried to put the first one together dry. The second one wasn't much better as the rings seem to squeegee the lubricant off. Now I put lubricant between each ring as I insert the fitting. Much easier.
Cord is offline
Old 03-31-2003 | 04:22 PM
jspeeddemon's Avatar
I put oil in the hose and then start sliding it on. For the straight fittings once I get it started I grab the hose and the end and smack it straight down, fitting first on to my wooden work bench. Goes together real easy and the wood is easy on the fitting. I got tired of cussing the damn things on. For the 90's and 45's I get two pieces of wood put the fitting between the wood in my vise and shove like hell, again the oil in the hose is key and doesn't make a mess. These fittings and hose never leak, are good to 250-300 psi, and can handle everything except brake fluid.
jspeeddemon is offline
Old 03-31-2003 | 06:40 PM
formula31's Avatar
So it is rated for gasoline service? Coast Guard approval? Are there fittings for the carb?
Old 04-01-2003 | 04:48 PM
Socketless hose is fuel rated, but not USCG, nor is Steel Braided line !
Elite Marine
14
09-15-2010 01:50 PM
jdub
6
03-11-2007 08:04 PM
Monty
5
05-13-2004 01:27 PM
Cord
10
08-20-2002 11:24 AM
RLW
07-11-2002 06:45 PM
