HP 500 Carb Upgrade to 650HP >
Old 03-29-2003 | 02:47 PM
Default HP 500 Carb Upgrade to 650HP
Who has a "kit" with bolt on
heads
intake
carb
ignition
I would like to increase my 500s to 650-700 HP.
Can this be done with a pump gas bolt on of the above parts?
I would like to leave the bottom end alone.
If I need a Whipple, do I need to do head, carb and ignition upgrades? I would think the MSD would be required to address the igher revs. I do not think the heads come from merc with inconel exhaust valves.
I understand Tyler Crocket has a kit that will run to 600 Hp.
Any idea of the cost to do this?
Shawn
shawn is offline
Old 03-29-2003 | 03:19 PM
Tinkerer's Avatar
All of the above plus header style exhaust and cam.
JIM V. can set you up. He can easily get 650 HP out of a 502.
Tinkerer is offline
Old 03-29-2003 | 05:07 PM
totalmp's Avatar
We offer a complete kit to make your 500 HP a 650 HP, 8500.00/engine includes complete rebuild w/ all new top shelf parts, Aluminum heads, Forged pistons, roller rockers, Manley Valves, Hydraulic Roller camshaft, Custom Painted w/ Custom Valve covers and Billet Flame Arrestor.
We also offer other packages that are each custom tailored to your engines. Feel free to give me a call to determine which will be best for you.
Thanks,
Steve
504-415-6681
totalmp is offline
Old 03-29-2003 | 08:56 PM
1Boatnut's Avatar
650 Hp from a 502 ? Naturally aspirated ?
Seen The Light
1Boatnut is offline
Old 03-30-2003 | 10:13 AM
Dennis Moore
Default Not very reliable though...
I think that you should consider the reliability of such an engine. It will need a camshaft with very fast opening and closing lobes with very high lift causing valve spring, lifter, rocker arm and valve seat wear. Be prepared to rebuild the valvetrain every 40 or 50 hours of operation. Compression ratios need to be elevated for such powerful camshafts or the engine will be a real dog at low speeds with very poor idle characteristics.
You better start thinking about an engine with more than 502 cubic inches so the horsepower will come from displacement and not wild valve timing and high rpm.
Some people say a reliable and smooth running engine can make that kind of horsepower on pump gas but I haven't seen one yet!
If it were easy and reliable we would all have 650-700 horsepower NA engines in our boats.
Sincerely
Dennis Moore
Old 03-30-2003 | 10:32 AM
Official OSO boat whore
I'm thinking that you will need more than just a kit. The entire engine will need to be gone through. The only exception would be if you added a 8:71. Even then, you'll at least need to change the pistons, so a tear down is still in order. I'd have to really question the reliability of a 502 making 700hp N/A.
Cord is offline
Old 03-30-2003 | 04:53 PM
Tinkerer's Avatar
650 HP out of a 502 is not pushing the envelope. The engine will run fine and stay togeather. It will have to run on prem. gas.
Tinkerer is offline
XtrmPWR
Do It Yourself, Boating on a Budget
4
09-08-2008 01:16 AM
Linster
05-17-2004 05:23 PM
Buddy OO
2
02-21-2004 08:38 AM
27daytona
1
05-29-2002 11:55 PM
Dean Ferry
05-15-2002 02:00 PM
