Things to check on the boat >
Old 04-01-2003 | 08:09 AM
Audiofn's Avatar
Charter Member #232
Default Things to check on the boat
I was working on my boat the other day and pulled out the flares and looked at them to be amazed that they were over a year out of date. OOOOOOOPS. Just figured it would be a good idea to compile a list of things to go through to make sure we all have a safe boating season.
Flares not out of date?
All life jackets ok and sized properly for all passangers?
Tighten all steering assemblies and drive brackets
Replace water pump impellers
Oil change
Shift and throttle cables working freely.
Ok now you guys add to my short list
Jon
Put your best foot forward!
Audiofn is offline
Old 04-01-2003 | 08:25 AM
CigDaze's Avatar
Check your fire extinguishers and/or automatic halon systems!
Check your belts for any wear.
Check your Zincs.
Grease your zirk fittings
Check the operation of your nav lights.
Test your Fume/CO detectors.
Check your bilge(auto float) pump operation.
CigDaze is offline
Old 04-01-2003 | 08:26 AM
X-Rated30's Avatar
Make sure the flame arrestors are polished to a mirror-like finish.
X-Rated30 is offline
Old 04-01-2003 | 08:28 AM
Wally's Avatar
Were doomed!
make sure bilge blower works and tubing is properly hooked up.
Batteries are fully charged. and connections are clean and covered. (Coasties will hit ya for no covers!)
-Wally
Wally is offline
Old 04-01-2003 | 08:31 AM
buck183's Avatar
Make sure First Aid kit is stocked. Although a box of tampons will do the same thing.
Buck
buck183 is offline
Old 04-01-2003 | 08:34 AM
Wally's Avatar
Were doomed!
Lets not forget the tool box.....including spare parts like belts and impellers (like audio said).....
And double check that bilge pumps work too!!
-Wally
Wally is offline
Old 04-01-2003 | 09:08 AM
CigDaze's Avatar
Of course, too often overlooked, check your drain plug before the first plunge.
CigDaze is offline
Old 04-01-2003 | 09:11 AM
GLH's Avatar
GLH
Check the balance in your bank account.
GLH is offline
Old 04-01-2003 | 09:12 AM
Wally's Avatar
Were doomed!
and carry a spare onboard too! Or a cork to plug the hole.
-Wally
Wally is offline
Old 04-01-2003 | 10:03 AM
R Addiction's Avatar
AT Cult Member #3
Get your grab handles redone with boat name included, install new crane rockers and 2 piece valve covers, And don't forget to ck your bank balances
R Addiction is offline
